suspension faults
Old Jun 2, 2018 | 10:10 AM
mhart08's Avatar
6th Gear
Default suspension faults
05 LR3, 116,000 miles
hey all, have had an issue with suspension faults daily for a while now.
most common is while driving (fault shows up 5-15 min) but ride height seems to stay the same.
Less common issues are apon starting vehicle, compressor will turn on then shut off after a few seconds leading to suspension fault.
Also Turning key to “on” position, the light that indicates height setting does not illuminate but will illuminate after cycling the key.
I have also noticed after being parked ride Height sometimes lowers
any help or options are much appreciated!
Old Jun 2, 2018 | 10:32 AM
abran's Avatar
Most likely it’s your compressor based on symptoms, but to be sure you need a code reader
Old Jun 2, 2018 | 03:14 PM
Rufflyer's Avatar
Default Compressor Over temp or over current limit
I agree with Abran.
If the compressor quits in less than a minute, it is usually because it gets too hot or over draws on current causing it to shut down. the rest of your problems appear to be directly related to no air in the system.
May be as simple as cleaning the dryer to let the compressor breath or as complicated as replacing the compressor and other air distribution parts.
Hope it turns out OK
Jeff
(general disclaimer---- I could be wrong)
Old Jun 2, 2018 | 03:15 PM
mhart08's Avatar
6th Gear
Default Thanks
greatly appreciate all your help
mhart08
Jun 8, 2018 07:26 AM
alti
Oct 25, 2013 10:45 AM
mirepoixmatt
Apr 27, 2012 12:53 PM
tyadams
Oct 19, 2011 09:25 PM
