Suspension help
Old Sep 19, 2018 | 12:01 PM
Baxmedic's Avatar
5th Gear
Default Suspension help
I own a 2008 LR3 SE 124k
i can not lower the supension down with the switch once I raise it to off road height. The truck does it once I hit 35mph so no problem. Does anyone know what I should be looking for to fix this?
Old Sep 19, 2018 | 01:43 PM
houm_wa's Avatar
Could be the switch....has that area gotten wet at all? How about the passenger side floorboard, any water intrusion there?
Old Sep 19, 2018 | 01:54 PM
Baxmedic's Avatar
5th Gear
well since I have had it no water on the switch but the first trip both a/c lines were plugged. I thought my daughter spilled water out her passenger back Door. Tonof water!
I did a road side fix on both. I did notice because I have weathertech floor mats.
Old Sep 19, 2018 | 04:45 PM
houm_wa's Avatar
Can you use the switch to go from Normal to Access height?
Old Sep 19, 2018 | 05:14 PM
Baxmedic's Avatar
5th Gear
nope no down at all it will go up only
Old Sep 19, 2018 | 07:54 PM
abran's Avatar
switch, its common
Old Sep 19, 2018 | 08:07 PM
Baxmedic's Avatar
5th Gear
Originally Posted by abran
switch, its common
ok thank you. My search begins
Old Sep 19, 2018 | 08:11 PM
Abran is usually parting a LR3 or 2 out. Might check with him lol
Geo
Dec 10, 2018 08:08 AM
Michael Sewell
May 20, 2018 01:46 PM
mnjaws
Apr 12, 2018 10:08 AM
BennyRover
Feb 9, 2015 11:20 AM
Externet
Nov 15, 2013 01:44 PM
