Suspension: Replace Bags only or Replace entire assembly
Is it possible to only replace the bags (to save a little money) or do we need to swap out the entire air strut assembly spring and bag?
Bags only: 2005 2009 Land Rover LR3 Front Air Ride Suspension Bags Pair New | eBay
Entire assembly: Brand New Arnott Front Air Shock Strut Assembly for Land Rover Range Rover LR3 | eBay
Yes, it's possible. Is it economically feasible? Not from what I've seen. Look at part number LR016503. From what I've seen, just the airbag is about as much as the entire assembly. Besides, by this point, I'm sure the shocks could use a refresh as much as the springs. There are also a bunch of o-rings/seals that you would want to replace. Part is LR016412 I think.
I just had to do this
I had a right front bag leaking. At 162,000 miles a complete strut/airbag was a no brainer for me. Also the install took an hour and forty minutes to do both front struts.
Considering that you can replace the strut with basic hand tools ....23 mm 22 mm 15 mm and a 12 mm wrench and a jack that can get the wheel off the ground.
One big bolt on the bottom and three small nuts and an air fitting on the top and your done.
shock oil went somewhere
I tend to be an advocate of replacing the whole assembly.
Beside the fact that it is easier to just install a whole new assembly, one might ask where the shock oil went
One must presume that the shock within is already somewhat tired and has lost oil. My thinking is that the oil is for the most part coating the inside of the airbag, hence all new has some additional benefits.
Just as an FYI, I believe Bilstein is the OEM for our shocks. They have a service where they will refurbish one of their shocks for around $100 and/or revalve for a bit more.
I called to see if they would service our OEM shocks and was told that "Unfortunately, we cannot service any OEM shock, we will only service our own aftermarket shocks". So, poo. I really thought it might be nice to get the shocks revalved for the added weight that I've put on the truck and then reassemble.
From what I've seen on the bags, it basically looks like they start to crack around the bend in the bottom part of the bag. Right at the point where the bend sits when you're in normal driving height. So... I suppose you might be able to prolong the life of your airbags by keeping your car raised or lowered while parking, though probably at the expense of your compressor. Pick your poison.
