Suspension System red Warning light
Old Mar 28, 2019 | 09:16 AM
Blackngold77's Avatar
Originally Posted by Laurie Pope
Thanks. Any idea what the cross articulation code means?
its a "secondary" fault caused by the sensor issue.
basically because the value from the sensor is so different from the others, the computer throws an error saying it cant calibrate the height correctly across all 4 corners
Old Mar 28, 2019 | 12:22 PM
Laurie Pope's Avatar
Thanks...Ordered the sensor yesterday...should be in Monday or Tuesday...should be fixed by the end of the week.
Old Mar 28, 2019 | 12:25 PM
DakotaTravler's Avatar
Please update once installed.
Old Mar 28, 2019 | 12:34 PM
Will do...doing some add-ons at the same time. Backup camera, improved roof rack, decided to replace all four sensors...cost of four in a kit (new, LR Parts) was about the same as the cost of two purchased individually...I am planning on this one being a keeper.
Old Mar 28, 2019 | 04:54 PM
houm_wa's Avatar
Main thing:
1. Check the bundle of wires that run along the frame rail in the wheel well of the DRIVER's side. They may be broken.
2. Re-calibrate the EAS after you install the sensor, if you end up installing one.
Old Mar 28, 2019 | 08:42 PM
Thanks. Checked them, wiggled them, they seem fine. I am going to change out all four sensors.
Brosnan
Jun 11, 2019 01:08 PM
LRn2zzzz
Nov 24, 2017 06:37 AM
Lr3edm
Aug 13, 2016 09:06 PM
Quin Ferris
Jul 21, 2016 01:22 PM
