Taking the ECM out, Anyone?
Old Nov 20, 2025 | 03:35 PM
cybercop's Avatar
Default Taking the ECM out, Anyone?
Has anyone ever taken out the ECM of the LR3
Battery gone! -- Check
Cover plate over Transfer Case ECU -- Check
Unplug the Transfer Case ECU and remove -- Check
4 5.5mm Screws holding the ECM housing in place --- NO WAY
If anyone has done it, how did you get the lower right screw out?
A ratcheting 5.5mm spanner? I do not think that would work.
Old Nov 20, 2025 | 04:18 PM
cybercop's Avatar
Old Nov 20, 2025 | 04:19 PM
cybercop's Avatar
Also, how do you take apart this wiring connector?
Old Nov 21, 2025 | 08:50 AM
Rufflyer's Avatar
Default May or may not work
It has been awhile since I did that, but as best I recall try these:
For the bolt: I used a short 1/4 drive socket, a universal joint and a short extension with a ratchet
For the connector: Pull out (or raise up) the big red thing then you should be able to press down on the retainer clip like most other connectors
Old Nov 21, 2025 | 09:44 AM
cybercop's Avatar
tried just getting a socket on it with universal joint and could not fit it between the bolt/screw itself and the body.
might need to get a little angle wrench and slowly back it out. Issue is, if that screw is the same length as the other screws, it will hit the body before completely backing it out.
I have no idea how they even assembled it.
Defender1009
Mar 8, 2021 10:39 PM
june82000
Sep 27, 2015 07:03 PM
vjm530
Apr 9, 2012 03:09 PM
wilson96rr
Jan 4, 2009 04:15 PM
BeanBean
Oct 12, 2008 02:32 AM
