Terrain response Cheat Sheet
Old Aug 19, 2017 | 03:22 PM
GBR.R's Avatar
Default Terrain response Cheat Sheet
Hi I seem to remember someone had made a Terrain Response cheat sheet with best settings for various Off Road conditions but can't seem to find it. Does anyone know who and where it was posted?
Old Aug 19, 2017 | 09:33 PM
thorgal's Avatar
The first setting on the TR is Normal Mode or "Special Programs off". Only thing of importance to remember here is that your LR3 is still in full time 4x4 with an even 50-50 split of power (front to back) when this is selected.
Second setting is Grass-Gravel-Snow. It is probably the most misunderstood setting of them all. Because it has the word snow, most people assume that it is the best setting to use in the snow and this is simply a mistake. It is intended to be used on hard packed surfaces that can be expected to be very slipery such as an ice covered road (not trail), the interstate during a rain storm, wet grass, and so on. It will cause your transmission to start out in 2nd gear (3rd gear when in low range). Will remove some sensitivity from the gas pedal andwill become very agressive at looking for and controling wheel spin. It will alsoremove some articulation inan effort to maintain better control.Never, ever use this setting during off roading. It is conter-productive to do so.
Next is mud-ruts. This setting allows the transmission to start in first gear even when using low range, thus allowing more torque to make it where it is needed. It will increase articulation and be a little more forgiving of wheel spin. Use caution if off roading in low range in this setting as it is a very strange feeling to be in first gear/low range until you get used to it. Better suited for mud, ruts, pot holes, gravel covered trails, snow covered trails, great setting for most off road situations with the exception of the next two.
Sand mode. Use it for what it is intended. It is the best setting for the deep, sugar sand like a trip to the beach. Dog-gone californians will not let me take my LR3 to any of the thousands of miles worth of coast hereexcept for Pismo Beach [:@]. It will cause your transmission to "hang on" to the lower gears longer before allowing for an up shift. That translates into more torque, something essensial in deep sand to keep the tires moving. It will also desensitise the DSC even further to allow for some wheel spin, all inan effort to make sure you keep forward momentum.
Finnaly is rock crawl. It will greatly remove control from the gas pedal, will allow for the greatest amount of articulation and will force the vehicle into Low Range. Use mainly for what its name implies.
To sumarize, buy good all terrain tires. Demand heavy duty package if you intend to off road at all. Use controled, steady gas when you loose traction to allow the ETC to do its job. Heavy on the gas is counter productive with very few exceptions such as when in mud and trying tospin the mud clear from your treads or when in sugar sand when high rpms are desired.
Jantiz
Feb 25, 2025 04:23 PM
puraces123
Mar 2, 2024 10:12 AM
paulstring
Off Topic
Jun 3, 2011 08:43 AM
yevgenb
LR2
Mar 25, 2009 11:10 AM
UglyDucklingLR3
Jun 25, 2006 02:46 AM
