Disco 3 hse Rear Drivers door will not open.
Old Aug 19, 2017 | 01:54 AM
Paul Mckenzie's Avatar
Default Disco 3 hse Rear Drivers door will not open.
My 2006 disco 3 hse tdv6 Rear Drivers door will not open. When listening to the lock it sounds as if this is working. All other doors working fine. Found a few threads that explain removing door trim but is this possible when the door is shut? Is there a way to open the door without removing the trim???? Cant find any videos or pictures on this subject. Any help would be great
Old Aug 19, 2017 | 07:34 AM
thorgal's Avatar
Will not open from outside of the vehicle or when you try to open from being inside ?
Old Aug 20, 2017 | 05:48 AM
Will not open at all. In or out. this is why i'm asking if it is possible to remove Trim with door closed????? I'm sure its something very simple but getting the door open to investigate??????
Old Aug 20, 2017 | 09:32 AM
abran's Avatar
I've never taken the panel off with the door closed, but I'm guessing it can be done.
move the front seat forward out of the way then find the best combination/combinations of adjustment to the back seat to allow access.
You have to remove the inner pull handle cover to accesss 4 hidden screws, the rest are visible.
good luck
ToddD
Jun 24, 2012 09:14 AM
Disco2inferno
Jul 14, 2010 02:22 PM
roverohio
Jun 11, 2009 06:22 PM
