Terrain Response stuck on "Grass Gravel &Snow"
Old Nov 18, 2016 | 06:23 PM
Patrick Duffy's Avatar
Default Terrain Response stuck on "Grass Gravel &Snow"
Very icy last night so switched the LR3 Terrain Response to "Grass Gravel &Snow". Today it will not select back to normal or any other program. Turning the **** has no effect. No error messages displayed other than the notice saying what program it is in. Wondering if disconnecting the battery for 30 mins may reset the ECU?
Old Nov 18, 2016 | 10:01 PM
cmb6s's Avatar
That would be my first course of action. Shut the car off and let it sit for 2-3 minutes. Then, disconnect the battery and touch the two battery cables together for 30 seconds or so. Reattach to the battery and see what happens.
Old Nov 19, 2016 | 05:28 PM
Will give that a try next time my wife is off work (nurse, goes to work in the dark and gets back in the dark!) Thanks!
Old Nov 27, 2016 | 11:12 AM
I tried the battery disconnect and ground yesterday. It did not fix the problem. I then plugged in my Autel which works fine on my Disco 2 and seems to work on the LR3 too. There were no codes showing. Checked everything I could. Unplugged it and the problem was fixed! Weird!
Old Feb 28, 2020 | 09:52 AM
Ilea Moore's Avatar
4wd High
Default Stuck also in GGS HELP!
I did the same thing with the battery reset and it didn’t do anything so I tried it twice and it still didn’t do anything did anybody ever figure out how to get it out of the grass gravel train mode because mines stuck and it pulls a hell of a lot of gas when you don’t need it
Old Feb 28, 2020 | 12:42 PM
houm_wa's Avatar
You sure about that? GGS Mode tends to take throttle AWAY when you step on the gas pedal.
Old Feb 28, 2020 | 01:13 PM
Ilea Moore's Avatar
4wd High
absolutely ... way bigger difference in gas milage on the expressway . But back to getting it out of the GGS mode . Any thoughts ??? I did buy it with new wrangler tires on it . Could it be that? Not sure if they balanced them.
Old Feb 28, 2020 | 01:54 PM
Could simply be a faulty switch
Old Feb 28, 2020 | 01:58 PM
Ilea Moore's Avatar
4wd High
but which switch ?? Middle counsel ?? Or like an actual switch under the hood ? . The **** itself turned it there . And turned back n forth at one point to other differentials , it’s just now not moving at all to the other selections .
Old Feb 28, 2020 | 02:23 PM
houm_wa's Avatar
I would try putting it in 4-Lo and driving it around and then selecting a different model, see what happens. ....just to perturb its state.
