Terrain Response stuck on "Grass Gravel &Snow"
Old Feb 28, 2020 | 02:30 PM
Ilea Moore's Avatar
4wd High
Originally Posted by houm_wa
I would try putting it in 4-Lo and driving it around and then selecting a different model, see what happens. ....just to perturb its state.
I will try that and get back ...
Old Feb 29, 2020 | 03:16 AM
Globetrotter448's Avatar
Does the **** turn if you have your foot on the brake pedal
Old Feb 29, 2020 | 08:10 AM
Ilea Moore's Avatar
4wd High
nothing changes , I put it in lower suspension , the mountain setting , the low mountain one too , still mo change when I turn the **** for terrain settings . She won’t switch to any other ones . I’m stumped guys . Is this something I can use my scanner to fix it ? I just got a iLink 400 in the mail yesterday .
Old Feb 29, 2020 | 08:49 AM
DakotaTravler's Avatar
I agree with Army, sounds like a switch. The vehicle will remember all modes even with battery disconnect. The only modes it will kick out of its rock crawl and mud & ruts, after 6 hours of the vehicle sitting off it will default back into normal. But the other modes, those stay it seems.
Old Feb 29, 2020 | 10:02 AM
Ilea Moore's Avatar
4wd High
which switch????
Old Feb 29, 2020 | 10:07 AM
Well there is only one, so.........
Old Feb 29, 2020 | 10:44 AM
Ilea Moore's Avatar
4wd High
ok so I need to replace the entire center console terrain assembly ? Im not seeing just the switch i the middle only the one piece. Perhaps I will clean it up a bit before spending 275 quid
Old Feb 29, 2020 | 11:22 AM
Correct, its an assembly but you can probably get a used one. You can take it apart, its not exactly easy since the plastic is a bit brittle, but its doable - just take it slow and easy. The **** itself pulls straight up.
And maybe you answered this, but the icon at the dial for snow/gravel is illuminated? If not then it could be just that the cable unplugged.
Old Feb 29, 2020 | 11:47 AM
Ilea Moore's Avatar
4wd High
yes the icon is illuminated . That’s why I was hesitant that its faulty
jackh
Sep 13, 2020 04:39 PM
lmj301
Jan 6, 2015 10:15 AM
loomy123
Jan 4, 2014 09:09 PM
BamaBelle
Sep 22, 2012 07:19 PM
co556guy
Jun 30, 2009 04:22 PM
