Test Drove an 06 SE V8, a few questions
Old Oct 22, 2012 | 03:07 PM
drewdub's Avatar
5th Gear
Default Test Drove an 06 SE V8, a few questions
Greetings LR Gurus.
I drove my first LR3 this past weekend - we are looking to get my wife a big comfy SUV that will double as an adventure rig. She LOVES the LR3 and I have always loved Land Rovers.
A couple questions. We test drove a 2006 LR3 SE V8 with 90k on the clock. Two owner vehicle, that appears to have had regular service. I have a few records and am going to call the two LR dealers it was serviced at for more info. The truck was clean and quiet and drove quite nice. I have a few questions, though.
When I put the truck in the highest suspension setting, the air compressor was continually running - is this normal? I did not hear the compressor running when the vehicle was in standard mode or access mode. There was a wooshing/water sloshing sound from underneath the driver's dash. I feel like I have seen mention of a "waterfall" noise, but I dont know what this indicative of and my searches on here have not given me an answer. Is this A/C compressor not draining? blockage of some other drain? The carpets were not damp.
What else should I be looking for? What are some known issues that should've been addressed in the first 90k? Asking price is $13,999. Seems to be pretty fair.
Old Oct 22, 2012 | 05:36 PM
ghengis86's Avatar
No, compressor shouldn't run continuously in off-road height. Waterfall sounds like air bubbles in coolant: needs bleeding. Also sign of potential head gasket issue
Old Oct 22, 2012 | 07:03 PM
patmac99's Avatar
4th Gear
I just purchased an '07 LR3 last week. I only hear compressor run when car starts (maybe for 15 seconds) and after I lower vehicle (maybe a minute). How does your tranny sound? Much noise coming from the undercarriage as you drive (at any speed)? The 'hum' coming from my undercarriage is louder than what I would expect. I'm trying to figure out if I have a problem or is this just inherent to the LR3. Good luck with the LR3.
Old Oct 27, 2012 | 04:21 PM
legendbridges's Avatar
I have an 07 with 75000 miles the whining/rubbing sound from the undercarriage turned out to be a bad rear diff. My service guy said you need to change the diff fluid in these every 30000 miles despite the rover recommendation of 75000 to avoid problems.
drewdub
Jul 21, 2012 12:26 PM
Spencerfitch
Mar 13, 2011 11:30 AM
DiscoMike2003
Nov 10, 2008 12:11 PM
Camdisco24
Mar 4, 2008 07:36 AM
