Throttle/Idle issues? Clean your throttle body asap!
Old Sep 21, 2015 | 01:42 PM
schwaggy's Avatar
Default Throttle/Idle issues? Clean your throttle body asap!
I was having an odd issue whenever I came to a stop, the car would idle so low the engine would shake.
Opened up the TB and while it didn't appear too dirty, I cleaned it thoroughly with http://shop.advanceautoparts.com/wcs...8_pri_larg.jpg
Making sure to get the edges of the butterfly.
WOW - problem gone.
Old Sep 21, 2015 | 01:51 PM
Niver39's Avatar
I clean mine and my MAF sensor every other oil change. Had the same problem as you did 😔. I also use BP 44K oil change as well.
Old Sep 22, 2015 | 06:11 AM
Ghaniba's Avatar
I would get a reduced engine performance message rolling down a long downhill grade. Occasionally it would also stall out when I went to back into my driveway...
Cleaned the TB and never had a problem since. It's amazing just how touchy they are! I've had cars be WAY more dirty and it made no difference after cleaning it!
So, I too, am a fan! Especially when it's a 20-30min job even if you don't know what you're doing!
Dave
Old Sep 22, 2015 | 11:01 AM
schwaggy's Avatar
Totally. I really didn't hold out much hope, especially when first looking and seeing how relatively clean it was.
Bam! - $4 and 30 minutes later and it's silky smooth.
Old Feb 10, 2018 | 04:52 PM
babyxbuffalo's Avatar
Tools needed? I'm having codes P0174 and P0171 show up and I was hoping this would be a first step.
Old Feb 12, 2018 | 11:25 AM
schwaggy's Avatar
A screwdriver and the aforementioned cleaner, some rags, perhaps an old toothbrush.
Old Jan 29, 2019 | 10:42 PM
shanechevelle's Avatar
Gonna add this to my list.
TBH does freeze up and has a purpose
And
I know how to bleed my rover.
good luck all! Hope you guys make it through the winter!
its about 15 here so far.
mikec205
Jun 9, 2017 06:26 AM
Jeff Blake
Mar 23, 2017 09:05 PM
wisconsinoverlander
Nov 16, 2012 12:25 AM
elboy0712
Feb 27, 2010 06:51 PM
tastandish
Jul 3, 2009 03:41 PM
