considerations while cleaning IAC
Old Feb 20, 2010 | 11:04 PM
elboy0712's Avatar
Default considerations while cleaning IAC
anything to be mindful of while cleaning the IAC. And any suggestions on what to use as cleaner?
Old Feb 21, 2010 | 08:26 AM
Why are you wanting to clean it?
If you have idle issues, clean the throttle body first and see if that corrects your problem.
Old Feb 21, 2010 | 08:34 AM
Yes, dont move the plunger at all.
Make sure you clean the port it goes into also.
Old Feb 25, 2010 | 12:03 AM
elboy0712's Avatar
ahh i see. ..... did the throttle body cleaning and tried to clean the iac i think i may have moved the plunger a bit as now it is idling high... so which way do i need to move it to head back in the right direction
Old Feb 25, 2010 | 05:37 PM
Which way do you move it now?
In the direction of the dealer.
It now needs to be re-calibrated.
Old Feb 26, 2010 | 01:28 AM
elboy0712's Avatar
Default damn
how major of an issue is this ... like does it need to be taken in asap. or can it wait a week or so? right now it idles at about 12-1500 when cold then idles normal when warm
Old Feb 26, 2010 | 06:41 PM
I would get it taken care of as soon as you can, you really dont want a cold engine running at 1200 rpm.
The IAC is what controls idle speed when the engine is cold, kinda like a choke on a carb, only it controls just air.
Old Feb 26, 2010 | 09:44 PM
elboy0712's Avatar
Default good point
strangely the car sat for three days.... then shen i started it no problems... idling at about 650 700 (just a tad higher cold) and it has been that way for two days now... its almost like the IAC sorted itself out... or maybe it was something else causing it ... either way im not one to look a gift horse in the mouth... so ill just take it as a good sign and keep my eye on it for a week or two
Old Feb 27, 2010 | 06:51 PM
Rock on man.
I agree, dont look a gift horse in the mouth.
vishrb
Jul 18, 2012 10:25 AM
alemurill
Jan 5, 2009 11:23 AM
jmt
Oct 14, 2008 10:12 PM
Switzer
Sep 18, 2008 08:51 PM
willlane
Nov 6, 2007 09:46 PM
