tighten or loosen the shift cable?
Old May 26, 2021 | 12:45 PM
ketchgould's Avatar
Default tighten or loosen the shift cable?
Sometimes my LR3 doesn't know it is in park. I need to push the shift lever forward, towards the glove box and then start the car while pushing.
Do I need to tighten or loosen the shift cable?
Thanks
Old May 27, 2021 | 11:35 PM
loanrangie's Avatar
Neither, you need to adjust it.
Old May 30, 2021 | 04:06 PM
DakotaTravler's Avatar
You may just need to lubricate it. Passenger side on the side of the trans. Spray some silicone lube at the cable end.
Old Jun 1, 2021 | 01:06 PM
ketchgould's Avatar
I will spray the fitting, thanks. It would seem the fitting would just need to be changed the smallest amount and I was hoping someone might know if i screw in the adjustment or would be screwing out the adjustment.
Thanks
Old Jun 8, 2021 | 03:10 PM
bidoulatt's Avatar
Banned
You could loosen the bolt that pinches the cable at the RD and take in the slack. Do this with the RD in the smallest rear gear.
You may still have to fine tune the shifting. Suggest you set the barrel adjustment to the middle of its range before doing this so you have some room Tutuapp 9Apps Showbox to adjust.
ajnolin
Nov 24, 2013 09:29 PM
Hirley Issayana Diaz
Mar 22, 2012 04:32 PM
challishodge
Aug 7, 2010 11:06 AM
summerfld
Mar 19, 2008 05:21 PM
amyrick23
Dec 29, 2006 09:10 PM
