Shifting from 4h
Old Mar 20, 2012 | 11:05 PM
Hirley Issayana Diaz's Avatar
3rd Gear
Unhappy Shifting from 4h
My discovery won't shift from 4H anyone know what might be the problem?
Old Mar 21, 2012 | 04:32 AM
More details - shift lever won't move from this position, can't go into N or P or R ? Transmission fluid level OK? Cable from shifter to XYZ switch pack on left side of transmission attached properly (should be able to see it move while someone shifts)?
Old Mar 21, 2012 | 07:16 AM
Assuming you have been able to shift it before and know how to do it, then the shift solenoid located on the t/case has failed. To fix this issue, you can replace it with a new one or have it removed to save buying a new one, if you do that you must remember to shift the tranny into "N" before shifting the t/case.
Old Mar 22, 2012 | 04:31 PM
3rd Gear
@Savannah,
thank you for the input I will double check on all of that.
Old Mar 22, 2012 | 04:32 PM
3rd Gear
@Mike, I have never driven my discovery off road before and would like to but I read instructions to place it in N AT 5MPH TO SHIFT tried that and still could not move from 4h, is it supposed to be on 4h on a regular basis?
aBs0lut30
Jul 5, 2006 10:43 PM
Jawbox
May 12, 2006 10:26 AM
JasonKramer33
May 2, 2006 05:30 PM
samsly
Apr 13, 2006 01:36 AM
adowgiert
Aug 27, 2005 04:53 PM
