Tire Pressure sensors for second set of wheels (TPMS)
Old Oct 27, 2015 | 09:49 AM
Jagfixer's Avatar
My light came on in the LR4 while driving thru town. Checked pressures and found no problems. Continued and monitor said Lft Rear no longer monitored and have not seen light since. Good!
Old Oct 27, 2015 | 09:59 AM
schwaggy's Avatar
I turned my TPMS off with the GAP IID tool. Too many lights for no reason. Well, probably my sensors are worn but I can monitor my pressures without help thankyouverymuch.
Old Oct 27, 2015 | 03:33 PM
morrisdl's Avatar
I was getting lots of right/rear not monitored on trips over 2 hours; Replaced the TPMS sensor in that wheel and seems to have decreased but not gone away entirely. Annoying, but Im not ready to disable the feature yet. Report back if you find a true fix. Thanks!
Old Oct 27, 2015 | 04:28 PM
DavC's Avatar
I'm running about 38psi up front, 42psi rear
made it to work today which is always nice. The office is ~50 miles from my house, after clearing faults last night and airing up everything a little bit I have not had any TPMS lights come on. Roof spare with sensor is at 40psi
Still looking around for confirmation that the vehicle can "learn" a new sensor. Will visit dealer at some point soon to check on other things, will ask.
Old Jun 27, 2020 | 11:55 AM
LR4er's Avatar
Default New wheels/ Tires no sync
I have a used LR4 2012 and it came with the original 19”. My friend gave me an original set of Land Rover 21”s that i switched to but I am unsure of which year those are. I took them to to get the TPMS reset which they did but it is not syncing with the computer in the car and keeps saying failure.. it seems like i need to find a way to sync the new sensors with the older car.. is this possible? Thanks 🙏
Old Jun 28, 2020 | 12:25 PM
DakotaTravler's Avatar
The LR3 and LR4 use two difference frequencies for the systems. 315MHz on the early and 433.92MHz on later systems. So your LR4 should be 433 but if the tires came from something with the other frequency they will not work.
rovernoob
Mar 30, 2015 10:34 PM
Young Baron
Dec 17, 2010 09:41 PM
05lr3guy
Sep 17, 2010 09:25 AM
Chrisinhouston
Jan 19, 2009 06:57 PM
Chrisinhouston
Dec 16, 2007 06:36 PM
