Total Lockout on LR#
Old Dec 25, 2014 | 12:04 PM
Georgiacats's Avatar
4th Gear
Default Total Lockout on LR#
LR3 Please help! We've been working on the heater fan switch. We must have left it in the on position, and we are assuming it drained the battery. The key fobs do not work and neither does the manual key open the driver's door. The security light still flashes inside on the dash. We can't figure out how to open the doors, rear hatch, sunroof or hood. We even tried to trickle charge the battery through the tow wiring harness.
Is removing the headlight the best way to open the hood-- or is there something else we can try to open any door?
Old Dec 25, 2014 | 12:06 PM
You should be able to get a jumper cable/or a decent charger on the positive terminal of the starter(the big cable), then connect the other clamp to ground. That should be more than enough to power the systems to get it open.
Old Dec 25, 2014 | 12:15 PM
4th Gear
Thanks Army Rover, but how do I get to the starter? I am so frustrated! I am about to break the window glass to get to the hood release.
Old Dec 25, 2014 | 12:26 PM
Passenger side back of the engine where it meets the bell housing. If you look in the lr3 section for the lucky8 build he does a fairly detailed write up on replacing the starter with pics. It should give you a pretty good guide to access it.
Old Dec 25, 2014 | 12:30 PM
4th Gear
Thanks --- I'd better hurry and get started. I will just be happy if we can get the hood up today. Then, I'll worry about the battery and door locks. It's so upsetting to have a giant immobile doorstop in my yard. But at least this happened at home!
Old Dec 25, 2014 | 12:34 PM
Here is a link to the section on the starter.
https://landroverforums.com/forum/lr...a-64305/page5/
Old Dec 25, 2014 | 03:04 PM
TOM R's Avatar
How does the door key not work in the door?
Old Dec 25, 2014 | 03:12 PM
Got me I figured LR3 are like the D2 and that stupid little rod snaps off.
Old Dec 25, 2014 | 06:50 PM
bbyer's Avatar
Default Round trailer socket at rear?
Connecting to the starter motor, while difficult is guaranteed to work.
I noted the comment re trickle charing thru the round trailer socket at the rear. It should work but will take time. One of the terminals should show as having voltage on it - not much but some. If so, you might try running power back thru that terminal. The terminal shown on the diagram marked as 12VDC Battery may show some voltage.
All you are trying to do it get the voltage back to where the door locks will work and hopefully if you can get the hitch to backfeed, that none of the fuses blow that protect the circuit. If one does, it is just a nusiance but what I am saying is do not try to run much thru the socket - just get the doors open.
Let us know how it all worked out.
Attached Thumbnails Total Lockout on LR#-lr3-nas-7-pin-round-socket-plus-4-pin-flat-vehicle-end.jpg
Old Dec 25, 2014 | 06:52 PM
x2 I'd love to know if this gets you in and how bad it was to do.
