Traction control kicks in...but...
Old Nov 4, 2019 | 05:09 PM
Philip Chan's Avatar
Default Traction control kicks in...but...
So - I've had difficulty with my rear locking diff. Well documented on here - apparently I need a new one.
However, is this problem related to the locking or not?
I have noticed, when going around some curves (and not necessarily in inclimeant weather) around 50kms (30 mph) ish the traction control will kick in. The curve isn't necessarily like a 90degree curve, but it does require a slowing of speed.
Normal or related to the rear diff now being "open".
(of note, when I take the same curve in my HSE RR, nothing triggers)
Old Nov 4, 2019 | 05:19 PM
DakotaTravler's Avatar
Can you pull codes? There may be a fault in there somewhere. But as far as I know when in "normal" mode, no programs, the rear diff will not lock - same for center. So it sounds more like a speed sensor issue to me. As you running stock tire sizes?
Old Nov 4, 2019 | 07:37 PM
abran's Avatar
You probably have a loose component in the front end. Worn bushings, wheel bearing, etc. Also a un calibrated steering angle sensor can cause that.
Old Nov 4, 2019 | 09:32 PM
All of what he listed and I’ll add the lower steering shaft
Old Nov 4, 2019 | 09:47 PM
replacing the sway bar bushing in the front soon. Had thought about the bearings both front and rear.
I believe my angle sensor is ok. Will check (gap tool?)
Old Nov 5, 2019 | 09:14 AM
abran's Avatar
Gap tool can calibrate it.
pilot063
Aug 22, 2012 07:20 AM
grandkodiak
Jan 4, 2012 09:09 AM
azaky
Nov 29, 2010 08:48 PM
69mgb
Oct 8, 2007 09:06 PM
trini defender
Defender
Dec 6, 2006 11:58 PM
