Transmission Clunking at Freeway Speed
Old 10-22-2019 | 05:10 PM
ljdiscovery's Avatar
Default Transmission Clunking at Freeway Speed
Like the title says, I am getting a clunking in the transmission while driving at freeway speeds. It is similar to the California Stop clunk that most of us experience in the LR3 and RRS 2005 to 2009. It isn't constant, it happens every few miles. Sometimes it is subtle, almost like a misfire, occasionally it is more pronounced. It seems to get a bit more active when the truck is warmed up. I rarely notice it on my drive into work, about 10 miles, 6 on the freeway. Ideas? Abran was concerned that the transmission may be on its way out. The truck has 42,000 miles on it. Transmission Fluid has never been changed. No transmission leaks. No CEL, no Fault Codes.
Thanks Phil
2005 LR3
2006 Range Rover Sport HSE
2010 Range Rover Sport HSE
Old 10-24-2019 | 09:39 PM
loanrangie's Avatar
I would do a fluid/filter change as a matter of course and a full flush just to get that old fluid out, then if problems persist start looking at other possibilities.
Old 10-25-2019 | 03:23 PM
abran's Avatar
I would also check the driveshaft.
In addition, cycle through low and hi on T case to see if you hear a clunk.
Old 10-27-2019 | 12:38 PM
I cycled through the transfer case from hi to low, I can here the actuator working but no clunking. I was driving on the freeway just now. I felt a little hiccup in high gear. I shifted over to M mode for the next 5 miles. I didn't feel any clunk or hiccup in M mode. I will crawl under to check the drive shafts when I get home. thank to all. Phil
Lygen
03-06-2011 04:11 PM
petercanston
08-06-2008 06:07 PM
mlshelton
02-08-2008 12:57 AM
Quick Reply: Transmission Clunking at Freeway Speed
