Transmission fault code limited gears 4-5
Old Feb 27, 2024 | 06:40 PM
Lysiamm11's Avatar
7th Gear
Default Transmission fault code limited gears 4-5
Ok i checked all the fuses replaced some miracle some lights went off on the dash $250 battery replaced brake switch months ago from advance auto idk how good they are for such a finicky vehicle sounds now like starter going now can this cause faulty code please help love my vehicle
2007 LR LR3 HSE
big ole F i failed lol
p0784
Old Feb 28, 2024 | 04:17 PM
DakotaTravler's Avatar
Umm..... what is the question?
Old Feb 28, 2024 | 04:31 PM
Lysiamm11's Avatar
7th Gear
Arrow limited gears 4-5 trans fault big F
My truck was fine then got a land rover scanner went thru did a couple things deflated the bags reinflated then daughter drove it went slow made it home HDC code no communication n trans mission code cleared others due to fuse blown but i cant seem to get thru the transmission code Also says p0784 But my starter sound rough stating now i am wondering if that could be an issue for transmission fault
Old Feb 28, 2024 | 05:07 PM
houm_wa's Avatar
I see you're not a fan of punctuation so ill follow suit check the battery
Old Feb 28, 2024 | 07:15 PM
Lysiamm11's Avatar
7th Gear
Default Transmission faulty could limited gears 4-5
I did replace my battery that was only 2 yrs old yesterday, still have code
hell pie
Jun 13, 2024 05:41 PM
Aszelasko
Feb 29, 2024 07:34 AM
Rustyking
Jul 19, 2023 04:40 AM
LRScott
Jul 26, 2009 10:10 PM
stevey88
Apr 3, 2009 11:03 PM
