Fault code
Old Jul 18, 2023 | 12:04 PM
Rustyking's Avatar
4th Gear
Default Fault code
Hi Guys,
Just got a Nanocom because of fault amber light.
Its saying fault p1000, lambda sensor upstream 154 times signal missing fault is currently present.
any ideas
Old Jul 18, 2023 | 02:57 PM
matt3502's Avatar
I just looked thru 3 different code lists, including the RAVE manual and cannot find that code anywhere.
Old Jul 18, 2023 | 03:08 PM
Rustyking's Avatar
4th Gear
ok thanks for looking, I cleared the faults, so will have to wait for some more
Old Jul 18, 2023 | 07:35 PM
JohnZo's Avatar
If you can go by the description, then pre-cat O2 sensor signal missing, lots of times, could be loose connection of the signal wire or wires, or bad sensor. Don't know which side?
Old Jul 19, 2023 | 04:40 AM
Rustyking's Avatar
4th Gear
Hi JohnZo,
Thanks for the info, I will investigate
za105
Jul 14, 2023 10:50 AM
bebushka
Feb 18, 2020 11:02 AM
krammark
Sep 15, 2016 10:15 PM
e36m3
Feb 11, 2014 10:45 PM
sharp
Feb 5, 2009 09:11 PM
