Transmission Fault when shift to drive the disappears
Old Jun 8, 2022 | 03:14 PM
Mark_LR307's Avatar
4th Gear
Default Transmission Fault when shift to drive the disappears
Hey All:
Small issue bothering me. Every time I shift my LR3 into drive the Transmission Fault appears then goes away after 1-2 seconds. This only happens once after starting it. If I'm driving and shift back to park and then drive again no error. But without fail every first shift after starting I get the message. Nothing coming up on the scan tool either (no error codes). There are no driving issues ever while driving that would suggest any real transmission issues.
Anyone smarter than me with some advice!
Cheers
Old Jun 8, 2022 | 05:43 PM
DakotaTravler's Avatar
Under the right side, NA models, there is the transmission shifter linkage. Lubricate it with silicone spray, liberally. Only slightly awkward to locate, but its very visible when you spot it. Try that first and report back.
ninjaff21
Jan 29, 2021 04:19 PM
bcolins
Dec 9, 2013 03:56 AM
bballjames
Aug 29, 2013 12:25 PM
gman21
Feb 18, 2013 02:40 PM
kids rover
Jan 14, 2010 12:20 AM
