transmission fluid change question...;)
Old Dec 2, 2016 | 10:08 AM
Roverrrgirl's Avatar
Default transmission fluid change question...;)
Hey guys, just need to confirm with you,..How many quarts does the trans. need when pan/filter changed? The kit comes with 6 qurarts of ZF Lifeguard but Im thinking 6.5 is what I will need ? Thanks for your input.
Also Prev. owner used Pentosin ATF1 and now the pan is leaking...can I add the ZF Lifeguard to top the fluid off while waiting for the new pan/filter?
Are the two fluids compatible? Thanks.
2006 LR3
Old Dec 2, 2016 | 12:03 PM
abran's Avatar
I'm sure the ZF lifeguard won't hurt the trans if you add.
you should use redline D6 ATF when you do the pan. Cheaper and just as good.
Old Dec 8, 2016 | 04:51 PM
djkronik57's Avatar
If you take off the pan, about 4-5 quarts will come out. The capacity of the whole transmission is closer to 9.5-10 quarts but most of that is inside the torque converter etc. and won't come out if you just take the pan off.
Topping off the fluid is not an easy procedure, and I wouldn't really recommend it. Since you are only getting half the fluid out dropping the pan, you are mixing fluids anyway. If they used ATF1, then you probably have a mix of Lifeguard and ATF1 anyway. I might be a little hesitant to go adding a third fluid in there as well.
See my advice on checking fluid level and topping off:
https://landroverforums.com/forum/lr...d-level-81408/
Old Apr 5, 2018 | 07:19 AM
Bernie Cordova's Avatar
2006 LR3
​​​​​​ Just curious to know how many quarts won' back in after the filter change?? Bout to do mine and unsure how much is the right amount... Thanks in advance
Athana
Jun 8, 2019 10:23 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
dalfier
Jun 21, 2007 01:45 AM
jmang
Oct 17, 2006 06:58 PM
