Transmission stuck
Old May 17, 2023 | 07:40 AM
richterjustin08's Avatar
Default Transmission stuck
I have an 05 that I just purchased with 250k miles on her , prestine condition . Previous owner said trans was slipping . So I tried to add fluid to trans because with her running there was no fluid dripping out . So I tried to add some yesterday with what kit I had . Just a hose blowing some in . I took her down road drive great but also would not pick up speed . She would take off at about 2500 rpm’s . Then after driving for about 10 15 minutes she would not drive anymore meaning you put her into gear and nothing .
SO … does she just need more fluid and I didn’t fill up enough or should I take her in because reverse is not working at all as well and the code pulled is for reverse , I think it was p0739. Ideas ???
Old May 18, 2023 | 12:18 AM
loanrangie's Avatar
I'd do a drain and refill with quality fluid and see how it goes, if you filled it using the correct procedure and it was just trickling out when you put the plug back in then its got the right level.
Would be due a valve body rebuild by now which would be about $750 or so well spent.
Old May 18, 2023 | 05:06 PM
So I did a fill and she has driven now and goes in reverse as well. But, after third gear, she will not shift to fourth so she stays at 3000 RPMs also to the tachometer she’ll jump up at 1500 RPMs and come back down to 2000. That’s where I’m at now .
Old May 18, 2023 | 08:21 PM
loanrangie's Avatar
Similar symptoms to what i had, rebuilt the valve body and it drives like new again. Have you had the DTC codes read, usually P0730-0736.
Old May 19, 2023 | 09:17 AM
That is roughly the code I think orielly auto parts told me .. that will save me a lot of money when I take it to transmission shop … thanks for help and I’ll let you know on Monday .
Old May 19, 2023 | 09:23 AM
If u have some web links to order valve body for decent price that would be awesome , that is the transmission shop doesn’t charge stupid amount
Old May 19, 2023 | 07:02 PM
loanrangie's Avatar
None that will help you since i'm on the other side of the planet, if you search the forum for ZF6HP there are a few posts that mention part suppliers.
Old May 20, 2023 | 10:16 PM
I did leave out another description that when I get up to 50-55mph she won’t down shift either keeps climbing the tachometer at 4000 RPMs if that of course higher the faster I go
RoverSE7
Apr 12, 2023 11:52 AM
yardpro
Nov 20, 2019 06:12 PM
djkronik57
Nov 24, 2016 09:58 AM
Timbuktu
Aug 21, 2014 08:58 AM
Jupe209
Aug 29, 2010 11:29 AM
