Uh oh. I think I messed up :(
I replaced the fluid in my rear diff. But I think I replaced it through the wrong opening.
I have HD package and refilled through the long hex bolt not the rear of the diff. I’ve driven a bit on it too.
What at is the bolt and what have I done here? And where is the fluid? 🤬
I know now if probably should have filled up here instead :
So. What can I do? I think I majorly messed up here.
Thanks abran.
I filled it via the first picture plug. I later found this was not a plug but more of a bolt. Then I found that this helps set the differential in some way . Have I messed up my diff?
Also. This is strange but I thought these e-diffs have a long hex bolt that sticks out far from the diff? Mine was just this....
