Uneven suspension height
Old Aug 15, 2013 | 03:32 PM
p8nt's Avatar
Default Uneven suspension height
Just brought home a 2005 HSE for the wife and have a question.
The front passengers corner seems to ride about 5/8" lower that the other 3. It does this in Access, Normal and Off Road. Holds position over night, so I don't think is a leak. No fault codes. Current on recalls.
Height sensor? Needs to be calibrated?
Any ideas are appreciated...
Old Aug 15, 2013 | 04:46 PM
houm_wa's Avatar
Could be a calibration issue, yes. If it were a sensor I'd think you'd get a fault.
Old Aug 15, 2013 | 08:20 PM
LR Techniker's Avatar
The Ride Level Module has the ability to adjust an individual corner, via the cornering valve, so its simply out of calibration or is getting bad info from a sensor. Its not unusual for a sensor to give issue, but I would try a calibration first, before hanging any parts on it.
Its rare when I see a Rover come through the shop with it identical on both sides. +/- a few mm is OK. Keep in mind that whenever the vehicle is in motion, your behind the wheel which will make the left side drop down a little bit.
Old Aug 15, 2013 | 10:40 PM
p8nt's Avatar
Thanks Tech.
Im new to this. Calibration = Trip to the dealer?
Old Aug 16, 2013 | 07:53 AM
The dealer can do it, but some indy shops can as well. There is a post floating around that has a list of indy shops by state, you might be able to find one near you.
Also try LRShops.com, its another locator service. Hopefully, anybody who claims to be a LR specialty shop, can do it. Call first and ask questions!
Old Aug 16, 2013 | 12:03 PM
houm_wa's Avatar
...also YOU could do it (in the future), if you buy an IIDTool from GAP Diagnostics. They are invaluable.
Old Aug 16, 2013 | 12:58 PM
jafir's Avatar
I'm tempted to get one, they are about $350 if you get them from the UK. They are about $550 in the US.... but I'm hoping that Blackbox gets their software updated soon for the nanocom. They are working on that right now supposedly. Hopefully I can just buy a license for less than $350.
ShadowMerchantBC
May 8, 2011 03:37 PM
quietcoolone
Feb 21, 2011 11:49 PM
sosico
Jan 6, 2009 08:52 PM
malmberg
Dec 16, 2008 06:37 PM
Prepilot_3ck
Apr 1, 2006 10:35 AM
