Updated Radio to Car Play bricked OEM nav
Old Feb 22, 2020 | 05:19 PM
Loriebluedico5's Avatar
Default Updated Radio to Car Play bricked OEM nav
Just updated to a CarPlay pioneer head unit. Had a local shop do it they said they installed everything required. The built-in NAV unit on the HSE is now only showing the Landrover logo. Is this something I’m now living with,
or is there a workaround I am not aware of. If this is something that happens and it’s guaranteed what are my options for that space I can’t stand just staring at a logo and a blank space.
Old Feb 22, 2020 | 10:05 PM
loanrangie's Avatar
Unless they used the correct loom then you are stuck with the LR logo and no satnav or 4x4 info.
Old Feb 22, 2020 | 11:03 PM
Sorry to say I don’t know what a “loom” is.
Old Feb 22, 2020 | 11:30 PM
loanrangie's Avatar
Wiring loom/harness.
Old Feb 22, 2020 | 11:56 PM
DakotaTravler's Avatar
Did your radio have a MOST connection? Two orange lines meeting at a black plug? If so, just put a bypass on it and you should be good to go.
https://www.ebay.com/itm/New-Most-Fi...s/223136521415
Old Mar 6, 2020 | 06:54 PM
Yes. I remember seeing them in there. So if I buy this item from
ebay it should work then.
also my subwoofer is now not working.
I wish this wasn’t so much of a problem. But I really do love having wireless car play now.
I also put in the tuf-tok power panel. Which I like
Old Mar 6, 2020 | 08:18 PM
They should as the MOST network will be complete again and not a broken loop.
No clue on the sub, it depends on how you wired it. The factory one depends upon the factory amp.
Mazook66
Nov 4, 2019 08:22 PM
zuke
Oct 20, 2016 06:15 PM
fo4imtippin
Jan 18, 2016 09:31 PM
KWAYZ
15
Dec 28, 2009 09:59 PM
