V6 > V8 swap
Old Jan 8, 2020 | 03:13 AM
mds's Avatar
mds
5th Gear
Default V6 > V8 swap
Hello all,
I'm new to the forum, but a long time Rover enthusiast! I currently have two Disco 2's (2000,2001), a 2006 LR3 (4.4), and a 2006 RRS (4.4 - non turbo). Interestingly, I bought the RRS with a "bad engine" that I planned to swap out, but it turns out their were other much more minor issues which have been fixed and now I find myself with an "extra engine" (the one I was going to pull from my LR3).
Our 15 year old son seems to be catching the Rover bug and would like the LR3 when he gets his license. The truck has a great V8 engine with 19X,XXX miles on it. I'm the original owner, have taken good care of it, and it still purrs like a kitten. Unfortunately due to a run-in with a deer, the body is a bit rough, the panoramic roof glass is cracked, and we lost the steering wheel airbag.
Recently found a deal on a 2006 LR3 with a bad V6 engine, but the rest of the rig is in great shape. I'm wondering if it is feasible to drop the V8 we have into this new truck without major issue. I guess I'd anticipate that the instrument cluster might not be happy due to mileage, MPG calculations, etc. I'm not sure if it's as easy as swapping the cluster or if it would require programming. Has anyone documented this swap? Can anyone comment on the feasibility of doing this?
I've got an Alldata subscription to the vehicle and on paper it seems doable. I've never done an engine swap, but I have a very well equipped home garage and have done some fairly complicated DIY vehicle projects in the past. I just didn't want to get into this and find out I need an expensive scan/programming tool. Or if I will need one, I just need to budget that and talk to my localish independent Rover repair shop and see what they'd charge.
Thanks for any guidance!
Old Jan 8, 2020 | 11:25 AM
houm_wa's Avatar
I don't know the feasibility a priori but I'd have to think that is is NOT feasible. So many ECUs and other downstream components to satisfy. Why not take the $ you'd spend on the V6 vehicle and put it into fixing the body/glass/etc on the V8 vehicle?
Old Jan 8, 2020 | 02:03 PM
abran's Avatar
Houm is right, Do yourself a favor and and abandon that idea. Is it possible? sure, but is it worth it is the real question.
Old Jan 8, 2020 | 08:06 PM
loanrangie's Avatar
Do a body swap retaining all the V8 donors ecu's.
Old Jan 10, 2020 | 04:45 PM
5280LR3's Avatar
Torque converters are different and assuming exhaust is too. If you want a V8 Lr3... that's what you should be looking for. Copart regularly has LR3's for sale if you want to get in cheap and do your own repairs.
Old Jan 10, 2020 | 09:58 PM
Nosugar0carbs's Avatar
Why not get the 4.2 sc RRs and have a supercharged Lr3? Just saying.
Old Jan 10, 2020 | 11:41 PM
mds's Avatar
mds
5th Gear
Thank you all for the replies! We will continue to hunt for another project.
Old Jan 10, 2020 | 11:52 PM
loanrangie's Avatar
As its only a project and if you have the space then go for, a guy in the UK has put a TDV8 into a D3 so nothing is impossible.
jesusfavela323
May 20, 2020 02:38 PM
GROVERDISCO
Jul 23, 2015 03:43 PM
MC04DII
Feb 6, 2015 01:13 PM
drowssap
Dec 25, 2011 08:38 PM
EL GALLO
Mar 9, 2010 10:24 PM
