Warranty Coming Due!
Old Nov 18, 2009 | 12:00 PM
saquib's Avatar
3rd Gear
Default Warranty Coming Due!
Hi - I just purchased a 2006 LR3. It has 44k miles and the warranty is set to expire in January 2010.
I wanted to poll people to see what I should have checked out before the warranty expires.
The following is on my list
1. Replace corroded Land Rover letters on hood
2. LCD display is hard to see on Radio. Replace?
Is there anything that I can have checked? Can they check the suspension?
Any advice is appreciated
Old Nov 18, 2009 | 12:32 PM
Well you have a list of items that are not very important, how about your truck in general, have you crawled under it, checking for leaks or broken parts, how about in the engine compartment, leaks or engine noises. Have you checked the operation of every switch for the entire truck???????????????
Go get busy.
Old Nov 28, 2009 | 06:10 PM
Navy_Jak's Avatar
These are my suggestions: in no specific order
1. Have dealership perform a complimentary 140 point inspection. This will ID required TSB's and Recalls not yet performed (if applicable)
2. Start shopping around for extended warranty.
3. Yes!, dealership will replace letterings/decals on hood and tailgate
4. Get faded control ***** on radio/temp control replaced
5. Check cracks on mooroof rails
6. Ditto on Disco Mike's suggestion to check every buttons and swiches. I discovered my rear A/C vents on floor did not work.
Anyone else got anything to add?
Old Nov 6, 2010 | 01:38 PM
Originally Posted by lovely09
Perfect!Well,some kind of checking should start on common parts.But yes a great way,have someone professional to check your car before the warranty expire.After all,it will save you more money knowing if there are problems and have them fix immediately before gets out of date.
I take it you didn't read or believe my PM to you earlier this morning, get rid of the links or you will be deleted this afternoon.
Landzu
Sep 29, 2012 09:10 AM
nmgirl
Dec 13, 2010 09:30 PM
nynole
Nov 2, 2010 03:48 PM
JayKay
Mar 17, 2006 11:50 PM
JayKay
Mar 17, 2006 12:26 AM
