Water inside my LR3
Check the rear drains to the sunroof. You can remove the rear cargo side trim to make sure the hose exits the car. You should be able to just pull the front part loose and get enough room to see the hose. Remove the screw behind the little cover plate, remove the seat belt connector with a T50 Torx and gently pull toward the center of the car. If you have rear audio controls on the top of the trim, pop the control out and disconnect it, or just be sure not to stretch the wires too far.
You should see it exit near the front of the rear wheel arch.
Jeff
Jeff
