Water inside my LR3
Old May 11, 2019 | 04:49 PM
stcalles's Avatar
Default Water inside my LR3
I have 2008 LR3 that was outside and it rained all night, next morning when I opened the back doors there was 2" of water accumulated and it came down splashing the driveway and wetting my shoes. Where is the water coming from? Do the back doors don't seal very well?
Old May 11, 2019 | 07:48 PM
DakotaTravler's Avatar
So you have two inches of water in your LR3? There are three common water entry points. The sunroof drains rot, so water can get in that way. The exterior A-pillar trim. And the windshield cowl can let water enter through the HVAC system (we filter, blower fan, etc.
Old May 12, 2019 | 07:25 AM
Rufflyer's Avatar
Check the rear drains to the sunroof. You can remove the rear cargo side trim to make sure the hose exits the car. You should be able to just pull the front part loose and get enough room to see the hose. Remove the screw behind the little cover plate, remove the seat belt connector with a T50 Torx and gently pull toward the center of the car. If you have rear audio controls on the top of the trim, pop the control out and disconnect it, or just be sure not to stretch the wires too far.
You should see it exit near the front of the rear wheel arch.
Jeff
greisinb
Dec 15, 2019 06:45 PM
AJ1
Oct 23, 2019 08:25 PM
Philip Chan
Feb 18, 2019 09:09 AM
kmelesky2
Feb 27, 2017 05:33 PM
ATXDisco
Dec 19, 2011 10:14 PM
