Water leak...OMG...will this ever end?
Old Feb 17, 2019 | 09:38 PM
Philip Chan's Avatar
Originally Posted by ljdiscovery
Philip I would start by checking the front right sunroof drain where in takes a 90’ turn out of the cabin. It is behind the central junction box. It is a pain to get to but it is doable. My 90 had come detached from the drain tube. Water flowed straight into the cabin into onto and underneath the carpets. I pulled mine up and stuck an empty gallon water carton under the carpet to give a chance to dry out. It took a few dry days, but all is good now. Some have suggested a hair dryer, I wouldn’t do that. You are likely to set the truck a flame. If you can pull into a garage and leave the door open it helps with ventilation. Phil
Thanks Phil - however, I had the carpets up waiting for the water to gush out the cracked 90 degree nipple...but there was nothing.
On the bright side I soldered and shrink wrapped my green/white wires. I now have a working remote!
Old Feb 18, 2019 | 09:09 AM
Blackngold77's Avatar
Check your AC drain lines as well (they are in the cabin below the radio stack. Best bet is to pull the hose out of the hole and push a few feet of trimmer line through the hole to clear any blockage.
Also, its only a few bucks and about 10 min to get a set of A-pillar clips with the pads and replace all of them on both pillars.
You can also do the drain fix on the pillar as well. At the bottom is a long plasic rod that goes into a hole on the a frame itself. The fix from LR is to cut off the plastic rod and use supplied tape to cover the hole on the A frame.
Most replacement pack of a-pillar clips will have the tape to do that fix as well.
greisinb
Dec 15, 2019 06:45 PM
AJ1
Oct 23, 2019 08:25 PM
gc3
Apr 24, 2019 11:14 AM
ATXDisco
Dec 19, 2011 10:14 PM
Thaniel
Feb 9, 2008 07:08 PM
