weird flashy light thingy happeningf
Old Feb 1, 2017 | 11:06 PM
abran's Avatar
Originally Posted by Dv8er
It is both headlights, and I do indeed have the Xenon lamps and it is only on startup. If I turn the ignition off and turn it right back on, the headlights do not wag at all. When I hooked up my IID tool today (about 7mins after the UPS guy dropped it off), I did see 2 faults - LH and RH headlights - short to ground. I cleared the faults as they were from Aug of 2015, and after reading faults again, they did not appear. I am wondering if this is something one of the PO's set up in Car Configuration...?
does your rover have fog lights?
we changed ours to xenon. Maybe it's an issue with the upgrade?
Old Feb 2, 2017 | 08:53 AM
houm_wa's Avatar
After you cleared the fault, did the problem go away?
Old Feb 3, 2017 | 02:28 AM
Dv8er's Avatar
I do have the foglights - guessing the xenons are an upgrade, as my foglights are halogen.
After I cleared the fault, the problem did NOT go away.
Sorry for my delayed responses - I am working nights this week and the middle of the night is when things calm down enough for me to get online.
Old Feb 3, 2017 | 06:03 AM
abran's Avatar
if you have fogs your car came with xenon headlights, that's why I asked.
Old Feb 3, 2017 | 09:32 AM
houm_wa's Avatar
Really? So...the SE models that don't have Xenons also don't have fog lights? What are in the little holes in the bumper? Are they plugged? I've never looked that closely.
Old Feb 3, 2017 | 09:51 AM
abran's Avatar
There is no hole, but there is a mold line behind the bumper that indicates where is should be cut or stamped out if fogs are required.
SE came with and without the upgraded lighting package which was around a $2,000 option at time of purchase.
if you have Foglights, you should have xenon headlights and the automatic switch on the dash.
No Foglights equals halogen and no auto lights.
I had a customer come in with an 07' with auto lights and fogs, but halogens.
I asked if it had been in an accident and he replied a very small one. I told him his headlights had been changed and he was not sure.
Checked the date on the lights and they were from 05'.
Old Feb 3, 2017 | 10:00 AM
houm_wa's Avatar
Interesting....thanks for the info!
Old Feb 3, 2017 | 10:03 AM
abran's Avatar
my pleasure. The metal pan vs OE pan capacity mystery will be solved by Monday, per your request.
Old Feb 3, 2017 | 10:09 AM
houm_wa's Avatar
Thanks man! That quandary is holding me back from going metal....
Old Feb 6, 2017 | 04:16 PM
Dv8er's Avatar
Lots of good info! Thank you all - though I am no closer to solving my headlight mystery. I took the vehicle to the Land Rover dealer here in Wichita last week - the tech there was baffled as well. He also missed an obvious leak on my transmission (coming from the wire bundle) so my faith in that paticular service center is diminished...
