Were is the window module?
I am pretty sure windows are ran from The BCM (Body Control Module). I could be wrong, would have to look at wiring but that is what I recall. Nonetheless the modules is really, if ever, at fault. I would pull the switch pad in the driver door and verify the lock-out switch is not defective, they do fail. But first you can try holding the down button for a minute or two. Basically for a stupid long time and see if the window comes back to life. It apparently forces some sorta reset. Sorta like how an inoperable sunroof also resets with this method.
