What did you do to your LR3 today?
Old May 1, 2019 | 05:25 PM
  #961
emerica243's Avatar
8th Gear
Those look really awesome. How much did it set you back?
Thanks. About $850.
Old May 1, 2019 | 06:26 PM
  #962
DakotaTravler's Avatar
Thanks, that is not as much as I thought it might be.
Old May 2, 2019 | 06:36 AM
  #963
morrisdl's Avatar
Amazing work! Inspires me to redo mine. thanks for sharing!
Old May 11, 2019 | 05:15 PM
  #964
Rover Rene's Avatar
I didn’t do it today but I’ll post anyway. I had to replace my front passenger side hub assembly as we pulled into Vegas a couple weeks back. Now I started to hear a grinding sound that comes and goes on the same hub that I replaced in Vegas.
Old May 11, 2019 | 05:18 PM
  #965
Rover Rene's Avatar
Also, since I upgraded my tires and installed some Old Man Emu coil shocks I’ve been getting a fault message about suspension special programs shutting off. Usually happens when I make semi-sharp turns even at slow speeds and when I hit 60+ mph. Anyone else had this problem? Thanks in advance.
Old May 11, 2019 | 05:26 PM
  #966
Do you notice for DSC going active? Light on dash comes on when it is doing it's thing
Old May 11, 2019 | 09:46 PM
  #967
So today I pulled both rear hub assemblies. They are ready to go to the machine shop on Monday for new bearings to be installed. One is really bad the other is just starting the downward slide. I found a snapped rear sway bar link while I was in there. I got that pulled apart. Also discovered I had a froze up left rear caliper and the pad was destroyed on that side. Just missed messing up the rotor so a little luck. I finished up a diff fluid change on the rear while I was there.
Chased down the coolant leak up front. I was feeling pretty good about my day even with the set backs, until I noticed the 07 was leaking oil. Looks like the oil cooler has sprung a leak on it. So tomorrow I will pull the one off my 06 to fix the 07 and order a new one to replace it.
So much fun....
Old May 11, 2019 | 10:25 PM
  #968
Rover Rene's Avatar
Yes I see it then soon after the HDC fault appears and special systems are shut off.
Old May 11, 2019 | 10:40 PM
  #969
krick3tt's Avatar
Didn't do anything as complicated as you guys, just blew out my air filter and cleaned out all the leaves in the snorkel spinner.
Old May 11, 2019 | 10:51 PM
  #970
Rover Rene's Avatar
So much fun....
Both huh! It was a pain when I pulled mine off but then again I had zero tools other than a framing hammer and a utility knife haha. I literally had to buy all the tools needed to do the job and I was parked at a parking directly under Vegas sun for 5 or so hours. So does it cost less to have the bearings replaced as opposed to replacing the whole hub assembly? I paid $180 for mine from Autozone but I could have gotten it for about $150 online if I would of had the time to wait for shipping.
