What kind of TPMS sensor
Old Sep 13, 2021 | 04:21 PM
hewitt.johnp's Avatar
8th Gear
Default What kind of TPMS sensor
I have just acquired a low mileage 2008 LR3 and have some issues with the TPMS system.
Can anyone confirm whether the 2008 model year tire pressure sensors are direct or indirect and whether they are 433 or 3154 MHz?
Thanks!
Old Sep 13, 2021 | 07:33 PM
DakotaTravler's Avatar
Not sure what you mean by direct or indirect, but they should be 315 MHz. You want VDO/Continental or Siemens sensors. Other brands can be problematic for some reason.
Old Sep 14, 2021 | 02:15 PM
8th Gear
Hi DakotaTraveler - Thanks for answering me.
TPMS can work in two different ways;
Direct TPMS gathers accurate pressure data directly from the tire valve via four dedicated sensors, reporting pressure information in near real-time.
Indirect TPMS uses the ABS system to approximate tire pressure, and motorists must drive a substantial distance before an alert will be generated.
I believe that Land Rover only uses Direct TPMS but I don't know that for a fact.
Old Sep 14, 2021 | 02:29 PM
AtlantaViking's Avatar
The Rover uses actual sensors attached to the valve stems - so it is a direct TPMS. I have another car (Mini Cooper) that uses the indirect method (no sensors). I like the Mini's better because it's just simpler and doesn't deal with battery issues etc...
Old Sep 14, 2021 | 04:53 PM
8th Gear
Thanks, Atlanta Viking.
OK - makes sense.
I too also own a Mini (have had a couple of them) and have had multiple issues with the indirect ABS sensors.
Old Sep 20, 2021 | 09:44 AM
jagmandan's Avatar
Hi John,
Check my post here for some part number details: https://landroverforums.com/forum/lr...14/#post703667
-Dan
Hagendaz28
LR2
19
Dec 14, 2021 09:21 AM
Phangster
LR2
Apr 7, 2021 05:44 PM
Black 18 Disco
Jun 4, 2020 06:43 PM
mroorda
Nov 1, 2012 08:15 PM
Bryan monchery
Mar 20, 2011 12:29 PM
