View Poll Results: What transmission fluid do you use?
Only ZF LG6 or Land Rover branded fluid
33.33%
Mercon SP
50.00%
Red Line
16.67%
Pentison ATF+1
0%
Other
0%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old Jan 25, 2017 | 08:05 AM
jgm1's Avatar
Default What transmission fluid do you use in 6HP26?
There is a lot of debate on transmission fluid.
What do you use in your 6HP26 transmission?
Old Jan 25, 2017 | 09:21 AM
djkronik57's Avatar
I chose MerconSP after extensive research. It was far cheaper (about $75 for 12 quarts) and is used in the same ZF 6HP26 used in the Lincoln Navigator. Also didn't find any negative feedback from the folks who have switched to it.
Old Jan 25, 2017 | 11:05 AM
LR Techniker's Avatar
On 6HP transmissions, we only use LifeGuard6. 5HP units get Pentosin ATF1 (not applicable to LR3).
Old Jan 25, 2017 | 08:26 PM
cmb6s's Avatar
I use LifeGuard6, but if/when I do my next flush, I will likely replace with MerconSP.
I use LifeGuard1 in the L322 (5HP tranny)
Old Jan 29, 2017 | 09:49 AM
jgm1's Avatar
Thanks for the replies. Based on the above and others' posts which show Blackstone analysis almost identical between LG6 and MERCON SP, I plan to go with the much cheaper and more readily available (in USA) MERCON SP. The only difference appears to be a red dye.
djkronik57
Dec 1, 2019 11:28 PM
Athana
Jun 8, 2019 10:23 AM
ToddD
Jun 26, 2012 06:58 AM
calebbo
Oct 12, 2011 09:54 PM
Disco Alan
May 5, 2009 06:00 PM
