ZF6HP26 valve body lost small parts
Old Jul 15, 2021 | 09:53 AM
NBean's Avatar
Default ZF6HP26 valve body lost small parts
I recently purchased a 2006 LR3 with a ton of issues, one of which being the dreaded 3-4 shift. Luckily the cause was pretty evident as the E-clutch bushing was very worn, however I made a big mistake while rebuilding the valve body! I set the small parts on a sheet of paper and the wind caught it and threw the checkballs everywhere! I ended up losing 1 check ball and 1 of clutch limiting valve.
Does anyone know where I can buy these small parts or maybe find a used (trash) valve body?
Thanks!
Old Jul 15, 2021 | 11:14 AM
douglastic's Avatar
call thectsc.com and talk to someone
they may be able to help you
Old Jul 15, 2021 | 07:35 PM
DakotaTravler's Avatar
Any local trans shop would likely have access to specs, sizes, etc and maybe even stock them. Was not the case with my BMW, but I used a metal b-b pellet instead.
Old Jul 16, 2021 | 12:34 AM
Alex J's Avatar
Try https://www.facebook.com/MZFBayerInc/ We used them for all of our ZF trans rebuilds and replacement transmissions at the BMW shop I used to work at. They are one of the only ZF authorized rebuilders on the west coast so I'm sure he knows how to get you the pieces you need.
Old Jul 16, 2021 | 11:42 PM
loanrangie's Avatar
Could always buy a zip kit which will have the parts you need.
Old Jul 26, 2021 | 12:59 PM
abran's Avatar
Yep, thats the best course of action. You should be using a zip kit if its apart anyway.
Old Jul 26, 2021 | 08:34 PM
You're alive, good to see you
Old Jul 27, 2021 | 08:27 AM
abran's Avatar
Just barely! Hope all is well
Ben Matheson
May 15, 2019 04:41 PM
RSPTex
Sep 23, 2014 01:16 AM
LRD2&ME
Apr 21, 2011 10:53 AM
alanroberts50
Sep 10, 2009 12:31 PM
jochvalve
Feb 11, 2007 04:45 AM
