2011 LR4 5.0 Head Gasket replacement documentation
Old 06-11-2020, 02:38 AM
AGLR's Avatar
Installed:
Oil filter housing and new filter
Accessory pulleys, tensioner and belt
Water pump
Front coolant tube
Thermostat and coolant lines
Spark plugs
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200611_003149.jpg
  #72
Old 06-11-2020, 05:08 AM
brandn3w's Avatar
5th Gear
Not much left!!
  #73
Old 06-14-2020, 01:48 AM
AGLR's Avatar
Fuel injectors installed
Fuel rails installed
Coils installed
Wire harness connected
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200613_234543.jpg
  #74
Old 06-18-2020, 02:22 AM
AGLR's Avatar
Early success...
Only time will tell.
  #75
Old 06-18-2020, 07:46 AM
huggi's Avatar
Congrats...... sounds smooth
  #76
Old 06-18-2020, 06:14 PM
brandn3w's Avatar
5th Gear
How exciting cranking it for the first time and then "Oh Thank God it's running!" Lol Very nice work!!
Quick Question: With a warm restart (eg. Restarting the vehicle after filling up for gas), does it make a warm 'knock' for ~90 seconds that disappears to the first video engine idle sound?
I'm curious if after all the work and timing refresh, if that's just the nature of this 5.0L engine.
Overall Great work and I hope you enjoy the fruits of your labor a while!!
  #77
Old 06-18-2020, 10:26 PM
AGLR's Avatar
We put 22 miles on it today just puttering around town. I did shut it off and restart multiple times and I can't say that I recognized any distinct knocking upon restart. I will listen a little bit closer over the next couple days and see if I can recognize what you're talking about. I have seen people online discussing a knocking sound that they seem to attribute to the high pressure fuel pump. These also run off of a cam so I could imagine them wearing out over time and causing a light tapping.
  #78
Old 06-18-2020, 10:39 PM
brandn3w's Avatar
5th Gear
It would be fairly noticable - thanks for the follow-up! I just see newer 5.0 build dates make the same noise so after your rebuild I was curious if it's absent now in the work you did or simply a noisy aspect of the engine.
Again - great work! Always fun to finally get on the road and enjoy the hard work.
  #79
Old 06-29-2020, 02:10 PM
sickws6's Avatar
Awesome Job!
  #80
Old 06-29-2020, 08:22 PM
AGLR's Avatar
Originally Posted by sickws6
Awesome Job!
Thanks!
200+ miles and still going strong.
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200629_181929.jpg
Quick Reply: 2011 LR4 5.0 Head Gasket replacement documentation
