2011 LR4 62k -tire pressure monitoring system
Old Aug 1, 2017 | 05:45 PM
drose's Avatar
3rd Gear
Default 2011 LR4 62k -tire pressure monitoring system
tire pressure monitoring issue - light came on indicating low pressure. there was a nail in the tire, post repair the light came back on. took it off at tire shop and there was no leak. now light is telling me that the tire is not being monitored at all....maybe a dirty sensor? any thoughts? thanks!
Old Oct 20, 2017 | 09:30 PM
annem_coleman's Avatar
I think you can calibrate them....look on you tube
Old Oct 23, 2017 | 07:58 AM
Racer X's Avatar
6 years on, it's safe to assume that the battery in the sensor has failed.
Replacement sensors are about $45 each at Rock Auto.
Old Oct 27, 2017 | 12:22 PM
drose's Avatar
3rd Gear
ok that sounds like the best path - replace the sensor. I also heard that it could just be the batteries?
Old Oct 27, 2017 | 04:27 PM
BritCars's Avatar
Likely the battery in the sensor at that age. But the battery isn’t replaceable so you have to replace the sensor itself. If you go to a tyre shop they have a wand they can hold near the sensor to test if it’s still transmitting and if the battery is low
Be careful about aftermarket sensors. Although in theory compatible some people have experienced intermittent comms issues with them. So if price isn’t crazy I’d suggest getting an oem one to be sure
Old Oct 30, 2017 | 01:31 PM
Racer X's Avatar
VDO is the OE manufacturer for the sensors that LR uses, I believe.
ljdiscovery
LR4
Feb 13, 2017 09:46 AM
ngv151515
Sep 28, 2009 05:18 PM
fanatic516
Sep 22, 2007 09:38 PM
oncorhynchus
Jan 21, 2007 02:14 PM
agavrilo
Nov 16, 2006 12:19 AM
