P0456 Evap Emission System Leak 2011 LR4
Old Feb 7, 2017 | 06:41 PM
ljdiscovery's Avatar
Default P0456 Evap Emission System Leak 2011 LR4
I did a search but can't find anything for the code P0456. My scanner shows that ithat P0456 is an "evaporative emission system leak detected (very small leak)." Does anyone have any ideas one where to start to look for such a leak. The gas cap seemed tight, but I loosened and re-tightened it. I cleared the code and will see if it returns. Any suggestions? thanks Phil 2011 LR4
Old Feb 13, 2017 | 09:46 AM
abran's Avatar
You will probably need to do a smoke test at the gas cap. Also check to see if there is any gas stains or smell coming down the side of the tank(for sure sign if gas tank fuel pump seal leak)
It's best done when the gas tank is almost empty.
The 2 most likely culprits will be your fuel pump ring seal or a bad DMTL pump.
If you find no smoke escaping the system(need to check from gas cap through all the lines fore and aft of tank to the engine) then you will have to assume it's the DMTL pump.
good luck
'BamaBoy
Sep 15, 2023 02:29 AM
robgusto
Sep 2, 2012 03:33 PM
rhyslegge
Oct 8, 2011 11:48 AM
joefresso
May 4, 2011 08:31 AM
Dell
May 1, 2009 08:09 PM
