2012 LR4 Engine warning light
Old Sep 5, 2025 | 06:22 AM
bluetembo's Avatar
Default 2012 LR4 Engine warning light
After the warning light first appeared, I followed the forum members’ advice and cleaned both MAF sensors, then replaced all four O2 sensors, but the issue still hasn’t gone away. I also bought one brand-new DENSO MAF sensor and replaced it test, but the warning light is still there. Now it seems like only very expensive work is left, so I’d appreciate some advice. The workshop is suggesting replacing the injectors, but I don’t think that’s the real cause.
Old Sep 5, 2025 | 10:40 AM
Richard Gallant's Avatar
Vacuum leaks can cause these too, you might want to review this post in the LR3 section https://landroverforums.com/forum/lr...-p0175-114974/
Old Sep 5, 2025 | 11:06 AM
bluetembo's Avatar
Thank you I will do
Old Sep 6, 2025 | 05:20 AM
Conch's Avatar
Had same 2 codes on my 2015 LR4 HSE SCV6 engine. Took the dealer a month (long story) to figure out it was the 2 High Pressure fuel pumps. Replaced those and seems to have fixed the issue.
Old Sep 6, 2025 | 06:32 AM
bluetembo's Avatar
Wow that can be expensive business !!
Old Sep 6, 2025 | 08:31 AM
AVLDefender's Avatar
I did the exact same thing. I also have a 2015 LR4 HSE.
Old Sep 10, 2025 | 06:13 PM
Conch's Avatar
Yes it was!
Old Sep 10, 2025 | 06:20 PM
Conch's Avatar
BTW - dont know how long mine had been bad as it started thtowing the CEL/codes within a couple weeks after purchase. And once the LR dealer did the HP fuel pumps, it didn't take too long before I started getting a code that the right bank CAT was bad. Reset the code & it came back within a few more weeks. Took it to an LR shop and they verified that O2 sensors were OK, and that if it had been running too rich for too long a time the CATs will get clogged and go bad! So best to get it figured out & fixed sooner than later.
bluetembo
LR4
May 4, 2025 05:06 AM
mirepoixmatt
Dec 27, 2022 02:40 PM
Mark Gregory
LR4
Sep 13, 2021 12:43 PM
ftsalonga
Jan 18, 2015 12:35 PM
Roverpatsfan
Aug 24, 2009 03:42 PM
