2015 LR4 - Suspension Fault - C1A20-64 Code
Hi,
During a rain storm, my 2015 LR4 HSE started tripping the fault code C1A20-64 with the dash warning of "Only Normal Height Available" early last week. After restarting the vehicle, the problem went away for a week. Yesterday, the fault warning returned again in the rain and went on and off throughout the day. The car isn't sagging overnight. When the fault warning isn't present, the suspension rises to off-road mode and lowers to access mode as normal.
I've read several discussions about this problem, mostly related to the older LR4s that have the Hitachi Air Compressor with the replaceable drier (dryer). My model with the updated compressor (the AMK) I've read is much more reliable.
The shop recommends I replace the air compressor. Are there other things I should test/replace first (e.g. relay, hoses, disconnect battery, pull a fuse, etc)? I don't mind replacing parts, but want to be sure it's the right part.
If I do replace the compressor, I've seen prices swing from $195-$1,000+ on Google. Some come with a lifetime warranty (FCP Euro). I don't need this to last me 100k, but 30-50k would be nice. At that point, I likely won't be driving the car regularly.
Examples -
1. https://a-premium.com/product/Air-Su...ariant=1172811
2. https://www.airsuspension.com/produc...ver-sport-l320
3. https://www.fcpeuro.com/products/sus...rnott-lr061663
Examples -
I'm no expert but I'm curious that you only have the problem in the rain. Have you checked the sunroof drains? There is lots of wiring in the footwells and if they aren't draining properly they can lead to an untold number of gremlins.
Wilybyrd
'10 LR4 HSE
Wilybyrd
'10 LR4 HSE
I'm guessing it's your compressor. Go with an OEM compressor. I'd almost guaranty your 2015 has an AMK compressor.
That said, if you do have Hitachi and unless you have a GAP tool, switching from Hitachi to AMK is probably a no go, as you need the GAP tool to reprogram the suspension computer. AMK isn't really more reliable than HItachi. That was the rumor for a while, but I think it was just because the rumor started around the time when all the Rovers with AMK compressors were still relatively new. I read that Land Rover only switched to AMK because the Hitachi factory was wiped out in the Fukushima tsunami.
In terms of best price, source it from a UK parts supplier, like LRCentre or LRDirect. Pricing is much cheaper for a genuine AMK unit, and shipping is astonishingly just as fast as from a US supplier. Make sure you have a ratcheting box end wrench for the top bolt, or an assortment of swivelly wobbely socket extensions. With the right tools, the job isn't hard at all.
