2016 Diff and Transfer Case Plugs
I need to change the fluids in the diff and transfer case in my 2016 LR4 (w/o elec diff). Atlantic British sells a kit but it’s only for years up to 2013. I called them and they said the fluids would work but the plugs might be different and couldn’t tell me what plugs the 2016 would need.
Does anyone have the part numbers for the drain and fill plugs on a 2016 LR4 differential and transfer case?
Turned out the Transfer Case plugs that came with the AB kit were too small. Here are the part numbers for all plugs on a 2016 LR4 with Open Diff and Single Speed Transfer case. Also should mention according to the workshop manual, the single speed transfer case requires BOT850 oil, not what comes in the AB kit.
Transfer Case:
Copper Washers: LR048842
Plugs: LR048841
Front and Rear Differentials
Fill Plug: TYB500060G
Drain Plug: TYB500110
Transfer Case:
Plugs: LR048841
