5.0 v8
5.0 v8
My understanding is this is a ford designed engine and is very similar to what was used in the mustang and F150 having the same timing chain tensioner and coolant leak problems. How close is this engine to the Land Rover version and are they at all interchangeable? The ford engines are much less expensive than the Land Rover variants, probably just do to more of them made.
If they are actually close, seems like a timing chain job on the ford version would be very similar if not the same as on a Land Rover. I’ve read about this repair being around $3-4k in a ford vs $7-9k on a rover. Something seems off here.
Will appreciate the education on this.
tks
tks
Yes the AJ series engines, 4.2, 4.4, 3.0 and 5.0 were developed by JLR with and under Ford's ownership and manufactured in the Ford Bridgend factory in the UK. There's some similarities between the AJ and the Coyote but they're not interchangeable and a Ford main dealer's NOT going to support JLR products.
The following 2 users liked this post by jeffh:
guy (04-13-2023),
mmbirtcher (05-04-2023)
The following 2 users liked this post by jahummer:
guy (04-14-2023),
Gsolo9559
08-21-2021 07:51 PM
