Air Suspension Lift Kit
Old Feb 20, 2021 | 06:26 AM
LR42016's Avatar
6th Gear
Default Air Suspension Lift Kit
I welcome hearing from others that have installed a lift kit on their LR4. I was thinking of a 1.5 inch lift kit (not too extreme) so I can ride higher in normal mode. Thank you.
Old Feb 20, 2021 | 07:38 AM
I have run the Proud Rhino and been happy with them.
https://lucky8llc.com/products/proud...3-2-5-lift-kit
Old Feb 20, 2021 | 10:32 PM
Oldman846's Avatar
I recommend the lucky 8 SYA kit. It uses spacers and rods to achieve optimal lift and air strut volume
Old Feb 21, 2021 | 07:46 AM
LR42016's Avatar
6th Gear
Thank you for the link and suggestion. Do I need to be concerned about running normal mode at +2.5in. higher for highway driving?
Old Feb 21, 2021 | 07:47 AM
LR42016's Avatar
6th Gear
thank you...I will check it out.
Old Feb 21, 2021 | 07:51 AM
Oldman846's Avatar
No concern at all. I do it every day. You still need an alignment afterwards, and should calibrate ride height with the GAP tool.
Are you planning on running larger tires as well, or just the lift?
mmarmolejo
Jan 6, 2026 07:07 PM
CameraDan
Sep 13, 2019 06:00 AM
cobbcj7
Freelander
Oct 5, 2016 12:46 PM
trini defender
Defender
Nov 30, 2007 10:16 PM
Brad Luchtman
Nov 19, 2007 07:14 PM
