Best oil for 2014 LR4 - SCV6 engine
Old Jun 27, 2025 | 02:08 PM
yesyesnono's Avatar
4th Gear
Default Best oil for 2014 LR4 - SCV6 engine
Hi guys,
What is the oil you guys are using for a 2014 LR4 with the SCV6? I have 80k miles.
The manual says 5W20. The last oil change I used Mobil1 5W-20 and before that Valvoline 5W-20 and I am up for another oil change shortly. What oil are you guys using? What is best for chain life longevity?
Thanks!
Old Jul 3, 2025 | 07:31 PM
jahummer's Avatar
I've been using Ultra Platinum Pennzoil 5W20 for the last 5 years/100K+ miles, changed every 5K miles. Research and reviews suggest it's the best oil on the market, 100% pure synthetic with fantastic additives, even provides an engine warranty and it's about the least expensive oil in the US market. Next oil change however I'll be changing to 5W30.
Old Sep 18, 2025 | 02:04 AM
Billywedlock's Avatar
Castrol Edge Extended Performance 0W-20 Advanced Full Synthetic
It is JLR approved and used on the 3.0 SCV6 from 2018 and backward compatible, apart from cold climate markets.
Old Sep 18, 2025 | 12:04 PM
Richard Gallant's Avatar
@Billywedlock Yea the SCV6 is ticky when cold on that stuff, quiets down after about 10 minutes of driving. And after about 30 minutes when the oil is hot much quieter I am going to try the old spec 5/20, when I change my oil and see if there is a difference.
It could just be my truck
Old Sep 19, 2025 | 12:15 PM
guy's Avatar
guy
At operating temperature, there is no difference between 0W20 and 5W20.
When the engine is cold, the higher fluidity, and thus flow of the 0W is appreciated as it improves time to lubricate effectively at startup.
fwiw
Old Oct 11, 2025 | 02:01 PM
yesyesnono's Avatar
4th Gear
What is strange is that the Castrol website oil finder says to use only "Castrol EDGE 5W-20" for the 2014 LR4.
Mobil 1 has no oil to recommend at all LOL
Pennzoil website says 5W-20 ultra platinum
Liqui Molly website says to use Special Tec LR SAE 0W-20
Amsoil website says AMSOIL Signature Series 5W-20 100% Synthetic Motor Oil
How come some state 0w and others 5w?
Old Oct 12, 2025 | 10:00 AM
guy's Avatar
guy
Easy. The spec was originally 5w... JLR changed the spec later on, following the number of cases where oil starvation at startup was identified as the root issue.
It seems the others have not bothered to stay on top of the requirement.
Old Oct 12, 2025 | 12:08 PM
@guy do you have any info on the oil starvation issue?
Old Oct 13, 2025 | 05:41 AM
guy's Avatar
guy
The TSBs do not air dirty laundry.
Shenanigans1313
Jun 7, 2025 09:28 AM
Tim D
LR4
Dec 6, 2023 08:23 AM
Luke87GT
LR4
Feb 4, 2023 06:30 PM
rogerh
LR4
Sep 10, 2022 08:56 AM
brokentruck
LR4
Sep 7, 2016 07:13 AM
