Coolant Level Low error - HELP
Old Sep 9, 2023 | 11:48 PM
jahummer's Avatar
Default Coolant Level Low error - HELP
One year ago I replaced the coolant expansion tank. Several months ago I started getting a coolant level low message. The first time, the coolant level was actually low and so I topped it off. However the message kept coming back. I finally had some time to look into this and fitted a brand new sensor. Sadly the error remains. I've checked the connector and harness and see nothing amiss, and for reference, nothing had been done to either prior to the error message. Anyone have ideas what could be the cause of this annoying message?
Old Sep 10, 2023 | 03:39 PM
abran's Avatar
Sometimes the float in the tank that the sensor is reading gets stuck in the lower position. You can try to remove the tank and shake it around to dislodge, if that’s your problem.
Old Sep 11, 2023 | 07:14 PM
jahummer's Avatar
Removed the tank and can see the float at the bottom. I can move the float up with a magnet but it sinks immediately. Lasted less than a year, Dorman brand, going OEM now.
sayvillerx
Jul 26, 2024 04:30 PM
Scrappyq99
LR2
Nov 25, 2016 02:05 AM
Rover72
Dec 13, 2010 06:18 AM
MikeLi
Sep 18, 2008 10:33 AM
Max_A6
Mar 5, 2008 08:52 AM
