Discovery 4 Climate Control / Temperatures
Old Jul 31, 2022 | 05:15 PM
Disco84's Avatar
Default Discovery 4 Climate Control / Temperatures
Hi Guys
Thoroughly stumped and hoping someone can help / point me in the right direction or whether I’ve lost it!!
Earlier today was playing around with climate controlled on my late 2014 Discovery 4, and noticed that no matter what I adjusted on the temperature controls, I couldn’t get them below 60.
The minute I go below 60, it automatically shows “Low”. I’ve pressed the air recirc button turned on / off - and held it down for 3 seconds, had it on / off - and adjusted so many different combinations to try and get it to show numbers below 60 like it’s always done, but it won’t do it and I’m throughly confused!!
Normally it’ll go down through the numbers and I can get it down to 16 - but for some reason it’s just not going under 60 before going to “low”!
I don’t know much about it all and I’m hoping someone can perhaps answer a relatively straight forward question of something I’m doing / not doing etc. or if there is another problem?
As mentioned, up until last week was scrolling through all the numbers down to 16 absolutely fine but it seems to be stuck on this and I’m a little confused!
Hoping that one of you kind lot can point me in the right direction / offer any advice?
Many thanks in advance
Old Aug 1, 2022 | 06:45 AM
Wilybyrd's Avatar
16degC converts to 60degF. Did you change your units by accident to English Units?
Wilybyrd
'10 LR4 HSE
Old Aug 1, 2022 | 06:53 AM
Disco84's Avatar
Wilybyrd
'10 LR4 HSE
YES!!
You have saved the day and the simplest of things I hadn’t realised I’d done!
I remember being in the car week before last and changing the display on the menu from Celsius Farenheit ( something I completely forgot about ) to see what the temperature was in the heat wave that we had, and hadn’t change it back!
When I saw your message, popped out to the car, changed the display settings for temperature on the main menu using the steering wheel, and you sir have just graduated from Hogwarts!! You’re a wizard - thank you so much!
All fixed and ever so grateful
Thank you
Peter Brookes
LR4
Apr 1, 2021 08:40 PM
elrocha69
Mar 30, 2020 08:06 AM
Drake Anderson
Feb 12, 2019 08:14 PM
Green Blood
Dec 22, 2018 04:40 PM
jasonsLR
Sep 3, 2005 02:39 PM
