Engine/Electrical Issue
Old Feb 23, 2022 | 01:40 AM
  #21
sh74's Avatar
Found it. On Android press the stop button, select screen shot and share
Old Mar 8, 2022 | 01:45 PM
  #22
rover11_'s Avatar
7th Gear
Update:
Took the truck in for service.
Mechanic did smoke test and found air leaks between mass air sensor and throttle body. Also found leaks from valve cover vent valves as well as a cracked valve cover.
Truck runs much better but still has very intermittent issue of stalling or running very rough. Sometimes it will just recover. Other times you need to shut down and restart.
Will check error codes next.
Mechano2020
Feb 27, 2023 05:19 AM
cbkearney
LR4
Mar 13, 2021 12:30 PM
thehulk
LR4
Nov 6, 2019 08:27 PM
Wesley Lueders
Apr 26, 2019 08:51 AM
