Expansion Bubbles. Blown Head Gasket?
Old May 2, 2024 | 10:31 PM
ericmoe's Avatar
Default Expansion Bubbles. Blown Head Gasket?
new expansion tank and cap after cracked at seam, fresh bleed. Wondering if head gasket compromised. Not sure test kit will read positive. No Coffee oil color, no steam. 56K engine in 2016 chassis LR4. Thank you in advance for any ideas for this friend's car.
bubbles
Old May 2, 2024 | 11:13 PM
Riese's Avatar
Have you ever had the engine overheated?
Old May 2, 2024 | 11:24 PM
ericmoe's Avatar
thanks yes - prior engine the owner melted. this engine overheated when the expansion tank split. A miracle if the gasket didn;t get compromised / head cracked, cylinder meltdown.. Although slight chance mechanic didn't bleed properly (wishful thinking)
Old May 3, 2024 | 12:15 PM
Riese's Avatar
I am think it's blown. Small but it will grow iver time. I am going through the same problem now. The issue with these engines is they are aluminum with small thread3d headbolts. When they heat up the bolts loosen up causing head gasket leaks. Jaguar/Land Rover has onown this. The good news is you are catching it early.
Old May 3, 2024 | 01:08 PM
Riese's Avatar
Check out this thread.
https://landroverforums.com/forum/lr...ntation-98876/
https://www.huhnsolutions.com/
The link below is the inserts. This will help prevent it from happening again. The key is never let it overheat. Definitely a challenge with all of the crappy plastic parts. Once that is done, it will definitely help make it a solid engine.
Kalani0115
LR4
Jul 16, 2022 08:38 PM
za105
Jun 2, 2016 12:10 AM
acamato
Mar 7, 2016 01:08 PM
Vokam03Disco
Jun 16, 2013 09:54 AM
allen
Sep 11, 2012 09:34 PM
